Quick Drop Enthusiasts
quickdrop debugging?
how do you debug quickdrop plugins when ran in the quickdrop environment? my vi's are non-reentrant and highlighting is on, but they never seem to highlight (but they are definately executing).
(4,981 Views)
Quick Drop runs in a private Application Instance. You can set a breakpoint at the beginning of your plugin diagram and save it. When you execute the plugin from Quick Drop, it will hit the breakpoint, and bring up the plugin diagram in the correct Application Instance. At that point, you can utilize all the debugging tools you need.
(3,976 Views)
excellent!
(3,976 Views)
