RF Measurement Devices
5600 Downconverter : 10 MHz Reference CLOCK
Hi RFSA Guys,
Is it possible to vary the  10 MHz Reference Clock and use  it ... for demodulation of RF Signals
to a new value ... lets say 9.9992 MHz ?
If this is possible, upto what resolution can I vary the clock..
Can I vary it terms of 0.1 Hz or 0.01 Hz.. Is the  10 MHz Reference Clock truly that stable ?
I have a competitor clock which is stable upto  0.01 Hz... but not in PXI Form.
If this is not possible, Can anyone suggest a PXI Version of a Variable Stable External Reference Clock ?
Basically, I am looking at varying the Reference Clock to vary my Symbol rate for a Device Under Test.
Thanks for your help..Smiley Happy
Dharmendra
(7,055 Views)
Hey Dharmendra,
The PXI-5600 has an onboard 10 MHz OCXO reference clock that cannot be varied. You can find more information about its stability in the 5661 Specifications.
NI PXI-5661 Specifications
http://digital.ni.com/manuals.nsf/websearch/AA95024F707A2BF9862573840056DE7E
Can you not vary your symbol rate by varying your IQ Rate? Or are you trying to achieve this on the fly?
Chris Delvizis
(7,026 Views)
Dharmendra,
You might also run into problems when the downconverter tries to phase-lock to that reference clock, since it's expecting 10 MHz. Can you tell us a bit more about what you're trying to do? There might be a different way to accomplish it. Thanks!
Chad B. » National Instruments » ni.com
(6,895 Views)
