RF Measurement Devices
5632: Internal software error -1074118583
Hello Everyone,
I have a TestStand sequence running LabView code; The sequence runs for long periods of time. I will get an occasional error coming from my 5632. I don't think it an issue with multiple sessions. If I restart the sequence things work fine.VNA error.JPG
(3,563 Views)
Hi Erickey,
This definitely looks like it's more of a VNA thing than a TestStand thing at first blush. When this error does occur, does it come from the same step consistently? If it does, I assume that step has a code module that talks to the VNA; is there a chance you could post that VI? If instead of restarting the whole sequence, if you just retry that specific step does it work? I'd think probably not, that kind of error might get the VNA in a bad step, but interesting to check.
Cason
NI Applications Engr.
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
(3,536 Views)
