RF Measurement Devices
5641R initialization
I use a 5641R IF Transceiver (and a upconverter 5610 just as amplifier). I work on data coding/decoding with modulation and demodulation. I always send the same thing but sometimes the result is not the same. I see little oscilation with saturation around my signal. But when I reboot my PXI the good result come back.
I think there is a setting which is not initialize correctly.
I don't know if I forgot something in the settings. Maybe there is a way to initialize all the setting without reboot
Cordialement,
Simon D.
CLA | Certified LabVIEW Architect
CTA | Certified TestStand Architect
(5,851 Views)
Hi Simon,
Although its too late to answer this question now but still posting if you need any info. I am not sure about the error you are getting but you may refer to : http://zone.ni.com/devzone/cda/epd/p/id/6195 . They have given a similar example in which they are integrating PXI 5641R with PXI 5610.
Hardik Asawa
(5,773 Views)
