RF Measurement Devices
5645R
  1. As per datasheet the phase noise of 5645R Receiver is -112dBc/Hz @ 1GHz at 10KHz offset.For our DUT, we have to measure phase noise of -138dBc/Hz at 169MHz @ 1MHz offset. Is it possible?
  2. Also is it possible to generate 2GFSK using 5645R?
  3. Is it possible to generate dual tone CW signal from 5645R Transmitter?
Thanks in advance
Message 1 of 1
(3,933 Views)
