RF Measurement Devices
All four S-Parameters
How do I view all S-Parameters (S11, S12, S21, S22) using the attached program? Right now, I am only able to view S11. I am fairly new at programming and LabVIEW. I know I have to use a for loop somewhere in the program but I am not exactly sure where. Basically what I would like to do is output the real and imaginary data from all four S-Parameters into a file on my laptop so I can graph them. I am using an Agilent N5230A network analyzer and I have downloaded the appropriate drivers (AGPNA). Attached is a copy of what I have so far. This is my first try at seeking help so I appreciate any and all assistance.
Thank You,
Jemal
(7,107 Views)
Hello Jemal,
I see that this question has remained unanswered for quite some time.
Is this issue still open?
If yes, then just let me know, so that I can try to help you further.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(6,970 Views)
In Multisim 13, I used this arrangement to get all four S parameters. View in polar to see all four. I hope this helps.
Harold Kinley
WA4GIB
(5,341 Views)
