RF Measurement Devices
CWS generation with Delay and Triggering
Yes, phase offset is not consistent, on every run it minimizes, like for 1Ghz I was 400ps, but for 1.5 It was below 75ps.
I want to know how to add RF interpolation delay property and where in generation part for adding it control on run time.
Message 11 of 14
(1,558 Views)
Use the interpolation delay attribute that I linked to in my first post. Only set it for one of your VSTs. Positive values add delay, negative values subtract delay.
Message 12 of 14
(1,553 Views)
kindly share the info for syncronization with 5644 ref clock instead of PXI clock. I want to know how it will be accomplished as currenlty I am using PXI clock. In comment, It was mentioned that do not use on board Ref Clock.But how to do synchronization with 5644R ref clock?
Message 13 of 14
(1,552 Views)
Synchronization will not be affected by which ref clock source is used as long as the clocks are the same. Frequency accuracy may be affected, but the difference between PXI clock and ref clock sharing is very small. If you want to hit the 5644's specs, then share the ref clock.
To do that, connect device 1 ref clock out to device 2 ref clock in. Set device 1's clock source attribute to OnboardClock and export the ref clock (see below). Set device 2's clock source attribute to ref in. That should be it.
Message 14 of 14
(1,547 Views)
