RF Measurement Devices
Combiner 2790 Usage
Hi everyone!
                     I have two RFs and I want to combine then to make 1RF. Can Anyone guide should I connect them to  CH01 AND CH1A and take outpur from COMA or is there any other channels which I have to connect. Kindly provide help in this, It would be really appreciateable
(4,477 Views)
@Zarrar,
Could you elaborate on what exactly we are trying to achieve here? Also I would recommend opening up the NI-SWITCH Soft Front Panel and exploring the different routing options that are available for this device.
(4,448 Views)
Based on the other user's post with the switch topology diagram, your two RF signals would go into COM A and COM B respectively and the COM A and COM B ports should be commanded to connect to the SUMAB paths. This will provide a combined RF signal at the SUMAB port that is made up of the signals connected to COM A and COM B.
(4,255 Views)
