RF Measurement Devices
Continuous Acquisition of GSM IQ data
Hi, When i tries to acquire GSM IQ data with filter active i.e else if (RBWFilterType == MODT_GAUSSIAN_FILTER) {; the code hangs at checkWarn (
niRFSA_FetchIQMultiRecordComplexF64 (rfsaSession,"",0, NUMBER_OF_RECORDS,numSamples,-1,waveform,wfmInfo));
while if i comment the filter i get the following error image attached.
What could be the problem?
(4,944 Views)
Am trying to test all the examples in the GSM analysis folder and they are all returning the same error .
​This shows probably the signal is not been detected or ? cause after closing it highlights
"checkWarn(niRFSA_FetchIQSingleRecordComplexF64(rfsaSession, "", i, numSamples, 2, waveform, &wfmInfo)); "
Same case applies to labview examples.
What could i be missing?
(4,935 Views)
Hi waciuri,
I took a look at this with my colleague who responded to your other thread here: http://forums.ni.com/t5/RF-Measurement-Devices/GSM-IQ-data-capture/td-p/3082271/page/2.  Currently we'd like to make sure that you are able to detect your GSM signal correctly in the soft front panel, as this error looks like the same issue in that the signal is not detected.  If we can trigger and see the signal correctly properly in the soft front panel, that should also resolve the errors you're seeing here in the CVI GSM analysis examples.
(4,891 Views)
