RF Measurement Devices
FM Demodulation with De-Emphasis
I am using a PXI-5661 Vector Signal Analyzer with LabVIEW 2014 and the NI Modulation Toolkit to demodulate FM broadcast-quality voice.  I need to apply a de-emphasis filter on the received signal to compensate for the pre-emphasis placed on the audio signal by the transmitter.  The MT Demodulate FM.vi does not appear to provide de-emphasis functionality.  How can I de-emphasize the received audio using the above configuration?
(4,350 Views)
Hey,
Have you tried using the VIs in the Signal Processing palette of LabVIEW?
Michael Bilyk
Former NI Software Engineer (IT)
(4,323 Views)
I'm aware of the Signal Processing pallet, but I was unsure how to implement the filter.  The de-emphasis filter I needed should be a low-pass filter with a time constant of 75uSec (in the US).  The filter should provide 6dB/octave of attenuation above the cutoff frequency.  it turns out that a 1st order Butterworth low pass filter fits the bill.
This post was helpful:
https://forums.ni.com/t5/LabVIEW/6-dB-octave-highpass-Butterworth-problem/td-p/2862100
Thanks for your reply.
(4,296 Views)
Thanks for posting your solution.
Cheers
Michael Bilyk
(4,294 Views)
