RF Measurement Devices
FM Modulation error in PDA Module mode..
Hi All,
        Anyone can tell me how can i change my FM modulation's front panel view and block diagram view in LabVIEW PDA Module?Until now i just put all my wave forms and slide bars together in one tab control and i tried to run on my PDA. But only one waveform can run properly and during the running time which is between PC to PDA one error message come out is 'unsupported prim' . So please anyone can tell me or can find error for me how to change front panel view for running on the PDA. The FM modulation's front panel view and block diagram view that i want to run is as shown in attach file. Thanks to all for your help and I am really appreciate for you all.
Thanks and best regards
Nyan Lin
(7,661 Views)
Hi Nyan,
Your application may contain functions or front panel features that are not supported in PDA VIs.  In the LabVIEW Help you can find details on the supported functionality by browsing to PDA Module » Creating PDA VIs and selecting "Designing PDA and Touch Panel User Interfaces" or "Developing PDA and Touch Panel Block Diagrams."
Jennifer R.
(7,609 Views)
Hi Jennifer_R
I would like to request for help that I found error that when i run my AM Modulation on my PDA device by using PDA Module and i use the AM modulation VI which is i downloaded from NI website. And i used the tab controls for putting all wave forms in one tab together. But only the carrier waveforms can run properly and when i want to see others modulating and modulation waveforms, its shows nothing. I would like to ask that did i need to change any controls in front panel or in block diagram? My AM modulations that i download from NI is as shown in attach file. I show also my front panel design that i put in one tab controls is also in attach files.
The link that to download the AM modulation files is http://zone.ni.com/devzone/cda/epd/p/id/5146
Thanks a lot for your help
Best Regards
Nyan Lin
(7,573 Views)
Hi Nyan,
Are you still receiving any error messages?  And when you say "it shows nothing" do you see a waveform graph or just a blank panel?
I would recommend trying to delete all of the indicators from the example VI you have downloaded, then create your own indicators from the Controls Palette of your VI located under your PDA in the Project Explorer.  Be sure to check what you do against the information in the help file that Jennifer_R pointed you to.
Brian A.
(7,560 Views)
