RF Measurement Devices
FSK modulation with symbol rate 9600 causes error.
I'm tryng to generate 2GFSK (2 symbols, gaussian filter ) with PXI-5670 RFSG. Modulation supposed to be  done with 3.4kHz deviation and 9.6 kHz symbol rate.
With these parameter I  get out of waveform memory error from ni-RFSG Initiate.vi.
Parameters are:
Symbol rate: 9600
FSK Deviation: 3400
PN Sequence order: 9
Samples per symbol:16
Filter parameter: 0.5
Filter Characteristic: Gaussian
Filter length: 8
If I change symbol rate to 24kHz or higher, signal generation works fine. Size of array Y in complex waveform is equal in both cases.
How can I get reduce actual ARB-memory usage?
(5,930 Views)
Hello M. A. Rimpelai,
I see that this question has remained unanswered for quite some time.
Is this issue still open?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,799 Views)
