RF Measurement Devices
Filtering a RF Signal in Labview
Hello Sastry,
I specify 100kHz for the IQ rate and that is what the actual returns to me.  You are correct in assuming that the I and Q data sets are arrays of real numbers that I changed into complex values and merged into a single array to feed the filter vi.  I did not get the picture you spoke of in your last posting.
Joe
Message 11 of 17
(6,539 Views)
I specify 100kHz and that is what the actual turns out to be also.  Yes the I and Q data are arrays of real values which I change to complex arrays and combine into a single array for the filter vi.  I did not receive the picture you spoke in your last posting.
Joe
Message 12 of 17
(6,539 Views)
Oops. I thought it got attached. I am sorry not attaching. Here it is... Look at the picture while referencing to my post.
Sastry Vadlamani
RF Principal Software Engineer
Aerospace and Defence BU
Certified LabVIEW Architect
Message 13 of 17
(6,535 Views)
Thanks, I am now seeing the correct signal on the spectrum analyzer but I am still not seeing that the filter is having any effect on the signal.  The sidebands remain present.  Any suggestions?
Joe
Message 14 of 17
(6,511 Views)
Hi Joe,
The sidebands might be happening within the filter passband.
  • Try reducing the alpha (that you have currently set to (0.4)
  • Which spectrum analyzer are you using? IF NI RFSA, then assuming that you might be modulation toolkit example, have you set the filter correctly? If you are non-NI spectrum analyzer, check that you have set the reference filter etc. correctly.
  • If no receive filter, then try Raised Cosine on transmit side.
That was kind of hand wave suggestions. Let me know how it goes.
Sastry Vadlamani
Message 15 of 17
(6,501 Views)
I changed some of the values on the filter and everything is working great. The sidebands are gone!!!
Thanks for all of your help, I appreciate it.
Joe
Message 16 of 17
(6,496 Views)
Fabulous. All the best with your application.
If you get a chance, please do let us know about your application. I would love to know.
Sastry Vadlamani
Message 17 of 17
(6,489 Views)
