RF Measurement Devices
Frequency modulation in NI-5641R
    I have an NI- 5641R IF receiver and i am using Labview 2009 SP1.
    I need to receive FM radio channels by using the above.
    Please help me how to do or send me any examples related to this....
(7,144 Views)
Have you looked in the example finder in LabVIEW? Do you have a downconverter to go with your 5641? If you do see here
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(7,137 Views)
Thanks GovBob.....
Now i am not having any downconverter. I am having NI PXIe-5641r only.
With this is it possible to do FM demodulation......
(7,127 Views)
I don't have that particular card. You would need the carrier frequency to be within the specifications of the 5641 in order to demodulate the signal.
(7,111 Views)
in RF communication library is a FM demodulator included: -> http://decibel.ni.com/content/docs/DOC-4068
Works with me - but without downconverter you would not fall in usual range of terrestrial FM radio stations (87 - 108 MHz). IFRIO just goes upto 80 MHZ as far as I remember.
Greets,
Lars
(6,832 Views)
     Thanks for your reply Lars.B. I am trying to use the FM demodulation in RF communication library but i am getting the demodulated output as zero.
     I am attaching my code below.
     Please have a look.
(6,815 Views)
In your FPGA code "input valid" is a constant value and "ready for output" not used.
"Input valid" should be wired to the feeding FIFO (in the way NOT[timed out?]) and "ready for output" linked to the output of your code - in this case "stream fifo 16".
"Ready for input" should control data source (here reading the FIFO "local") - only not necessary when your timing of the feeding source is always slower than the processing part (e.g. when atan is set to 1 sample per tick).
Actual the data flow is uncontrolled, so that the demodulator is not processing the correct (valid) data.
Also, I don't think that there will be 65500 elements in one second timeout... try a lower value (like 2000).
Maybe take a look in the example in the library, there it is how it works..,
Greets,
Lars
(6,811 Views)
