RF Measurement Devices
Help in Dumping Data to Excel
Hello All
I have problem dumping data to excel. Basically, i created a VI to get some data using my TV test receiver (via RS232) and send the data to an excel spreadsheet. It saves the data no problem but it does it vertically. I want it to be save in Horizontal format. Can anybody give me an example to do this?
Many Thanks and more power.
(7,209 Views)
If you are using the write to spreadsheet VI from the functions pallet, there is a Boolean input at the bottom called "Transpose?". If you wire a 'True' constant to that input you should transpose your data so that it appears horisontally instead of vertically.
Ian
National Instruments UK & Ireland
(7,192 Views)
Hi
i guess using transpose function works. and if ur using TDMS file stucture then u have to use an addon to make that work.
regards
sam
(6,804 Views)
