RF Measurement Devices
How to generate such waveform on 5670?
I don't know how to set up I and Q for the waveform as the attached file. Can you help me out?
(7,042 Views)
You will not be able to generate this signal with the 5670. The 5670 has a real-time bandwidth of 20 MHz and your 10 MHz noisy square wave has a bandwidth of 500 MHz. In general, to convert a real signal to an IQ signal you must perform SW downconversion from the center frequency of the real signal's spectrum to 0 Hz. These SW downconversion tools are available in National Instruments' Spectral Measurements Toolkit and Modulation Toolkit.
Andy
(7,039 Views)
