RF Measurement Devices
IQ Phase response
Are there any available modules that can be used for IQ measurements?
Looking at PXIe-5645R which has an IQ ports, the phase mismatch between channels is around 0.1 to 0.5 degrees.https://www.ni.com/docs/en-US/bundle/pxie-5645-specs/page/specs.html
Would there be an alternative digitizer or other RF hardware having this feature? The price of the VST is around 3X of an digitizer and am not using all the VST features, i only need to have the I & Q ports and measure their magnitude and phase.
(4,843 Views)
You can look at either a dual channel AC coupled NI Oscilloscope, or one of the dual channel baseband FlexRIO products.
You will have to consider you bandwidth/sampling rate, and your desired resolution and dynamic range.
I haven't looked at these closely, but here a quick grab.
Oscilloscope:
5122
5124
5114 (only 8 bits)
5170R
FlexRIO (Note these adapters require an FPGA module):
5781R
5782R
5762R
5733R
5732R
5731R
(4,829 Views)
