RF Measurement Devices
Msk Receiver on USRP
I am new in labview, i want to Received MSK Signal on usrp2920 which is transmitted by niRFSG Example but the received signal have no constellation plot like MSK and not recovered bits, the bits at receiver end change continuously and BER is 1.kindly Guide me.
Thanks in Advance .
(2,905 Views)
It sounds like you're not synchronizing the acquisition to capture the data.  Which example are you using as a starting point on the receiver?  I'd suggest taking a look through the RFSA examples to see how they use the synchronization parameters and set up triggering.
Jon F.
Technical Support Engineer
(2,879 Views)
