RF Measurement Devices
NEXJEN-VISN-RFID iqx format
We recently purchased a new testing equipment from Nexjen. The URL for the equipment is <http://www.nexjen.com/Home/NexjenVISNRFID/tabid/206/Default.aspx>. The problem is that when I ever I want to save the measured responses it saves it in a .iqx file. I was wondering if you guys know how to convert that file into text file with the correct values in it. I attahed a sample file with this message. thank you in advance for your help.
(5,772 Views)
balsaify,
It seems the .iqx extension is a custom file format developed by Nexjen.  I would recommend contacting Nexjen to see if they have a converter or can provide you with the file format details.
Sam K
(5,748 Views)
Thank you, I will do that.
(5,745 Views)
