RF Measurement Devices
NI Recorder System
Any available solution for recording signals with 500MHz bandwidth with expected power signals around -150 dBm?
Operating frequency is around 4GHz.
What available hardware modules can be use?
(4,792 Views)
The only RF instrument we have with a bandwidth of 500MHz or greater is the PXIe-5668R:
https://www.ni.com/en-us/shop/model/pxie-5668.html
The signal power may be a problem however, as the noise floor at 4GHz is specified to be -161dBm/Hz.  So for a bandwidth of 500MHz, you would see a noise floor of -162dBm +87dB, or approx -75dBm.  You would need to amplify the signal.
Jon F.
Jon F.
Technical Support Engineer
(4,775 Views)
