02-14-2016 05:00 PM
Hi.
I have a PXIe-5644R NI device and need to use mobile WiMAX generation toolkit for some tests. However, when I run it, there is an error appears saying:
" NI-RFSG hardware device not supported. Supported hardware -NI PXIe-5673 and 5673E."
Is there any solution to use WiMAX generation toolkit on the PXIe-5644R device?
many thanks,
Sam.
02-15-2016 01:28 PM
Hi Sam,
Sadly, the WiMAX Generation Toolkit is not supported with the PXIe-5644R. You can find the compatibility of toolkits and hardware here: http://digital.ni.com/public.nsf/allkb/5D5DBD0E89701A6986257E930056D080?OpenDocument. The WiMAX Generation Toolkit requires a specific Vector Signal Analyzer and a Vector Signal Generator, and the 5644R is a Vector Signal Transceiver.
BeenCoughin
