RF Measurement Devices
Need Help Generating Custom Bitfile for PXIe-5644R in LabVIEW 2018
As the title states, i need to find out how to generate custom bitfiles for the aforementioned VST using LabVIEW 2018. It can be done on LabVIEW 2012 as I am currently using. However, LabVIEW available on a different, better PC where i want to generate the files is 2018. Therefore, i would like some guidance in this regard.
(3,727 Views)
If i can program the DIO ports of the FPGA without having to generate customized bitfiles, that would work as well.
(3,719 Views)
You can't program the DIO ports of the VST without generating a custom bitfile.
There are two options for programming the FPGA on the VST, the instrument design libraries and FPGA extensions.
https://www.ni.com/docs/en-US/bundle/ni-rf-vst/page/programming.html
The latest version of the IDLs supports up to LV15.
https://download.ni.com/support/softlib/RF/NI%20VST/15.0.2/readme.html
(3,698 Views)
