RF Measurement Devices
PXI 5620 Initialize Error
Hi
I am running into a problem. It has been a week but couldn't figure it out. I have PXI 5620 Digitizer and Labview 2010 SP1. The error only occurs when I run EXE, not in debug.
Here is the error:
LabVIEW:  Open VI Reference no longer matches VIs in memory by filename. A filename is no longer sufficient because the full name of a VI now includes any owning libraries.
VI Path: C:\SWA-1302-003 2.4GZ FT\2.4GZ Final Test Application\2.4GZ Final Test.exe\1abvi3w\vi.lib\addons\Modulation\niScope\mod_Set Receiver(RFSA).vi
(5,963 Views)
Have you taken a look at this KB?
I can't see your whole VI (or potential sub VI's), so it might be helpful to post that.  It seems like you are passing a VI reference name at somepoint, and when this is compiled into an executable, it is no longer looking in the correct location.
Are you building an installer or an executable?
Jon S
(5,935 Views)
I see "1abvi3w" as the folder name in the path where the real LabVIEW folder name should be!?  Why is that strange-looking name used?  We're having the same problem trying to execute our built app that uses a Report VI.
(5,901 Views)
Hello, can you post the related screen shot of where you are referencing the VI.
Are you using the Open VI Reference function or are you getting a VI reference another way?
Anthony F.
Staff Software Engineer
(5,876 Views)
