RF Measurement Devices
PXIe-5644R Digital ASK modlation generation
Hello All,
In my application, I need to generate ASK modulated waveform at 3.6G with <300us ON time & 10% duty cycle. Is it possible to generate such waveform with NI PXIe- 5644R VST?
Please suggest if any alternative method, or need to install any drivers.
Thanks in advance,
Swamy.
(3,023 Views)
Hi Swamy!
You can select the OOK modulation type using the PXI/PXIe-5650/5651/5652. But you are using PXIe-5644R so, you cannot select this property.
Please refer to below link.
http://zone.ni.com/reference/en-XX/help/371025V-01/rfsg/modulation_modes/#OOK
So, you should code generate ASK modulated waveform. I think these links are useful.
https://forums.ni.com/t5/Example-Code/RF-Simulation-Demo-Amplitude-Shift-Keying/ta-p/3996392
http://www.ni.com/example/30149/en/
Before you run these examples, download NI Modulation Toolkit in NI site.
Sebari.
(2,724 Views)
