RF Measurement Devices
Passing values between FPGA loops (5644R)
Does anybody know how the code for this example can be obtained?
https://forums.ni.com/t5/Examples-and-IP-for-Software/Power-Servoing-Example-for-the-NI-PXIe-5644R/t...
The "Latest Version" link goes nowhere.
It might answer a question I have about the best way to pass values between FPGA loops.
Thanks.
(5,375 Views)
I see the code for this example is missing too:
http://sine.ni.com/cs/app/doc/p/id/cs-15542
Is there a new repository somewhere that I'm not finding?
(5,371 Views)
Hello emonk,
Do you have the VI Package Manager (VIPM) – JKI currently installed? You can download it from:
https://www.ni.com/en-us/shop/product/jki-vi-package-manager.html
Also check if you have the required version for this example (LabVIEW 2012). Regarding “Creating a Software Defined Radar System Using NI USRP and LabVIEW” this is a case study so the code is not necessarily available.
Regards
Jose R
(5,350 Views)
Thanks, Toto, the lack of the VIPM on this machine was indeed the issue.  And yes, it failed to open on LV 2014.  Oh, well.
I've been handed a list of VST projects to execute, most of them concern building tracking generators.  I haven't been issued an actual VST yet but I'm dissecting every scrap of example code I can get my hands on.  Looking at the streaming demo I see that I don't necessarily need separate loops for the transmit and receive sides after all.
But...I have a feeling I'll be pestering this board quite a bit when my hardware shows up.
Vector modulation?   Fractional interpolation?  Basecard PLL status registers?   This may take awhile.
(5,335 Views)
