RF Measurement Devices
RF receiver
hi, I am new to Labview. I want to implement (simulation of) receivers that are homodyne and heterodyne receiver in labview and want to get the SNR and BER plot. can i do that in Labview.
Following elements are involed in those recievers: Low noise amplifier (LNA), mixers, bandpass filter, Lowpass filter, Analog to digital convertor i.e sampling and quantization
(5,778 Views)
Accepted by topic author muzzammil.khattak
There is no built-in functionality in LabVIEW that would directly allow you to simulate these components. However, if you know the math behind them, you could write the code yourself to simulate these parts.
You may also want to look into the Modulation Toolkit for some of the signal processing you mentioned.
(5,732 Views)
Ok. Thank you
(5,723 Views)
