RF Measurement Devices
RFSA 5660 Programming
I am transmitting a BURST of 200 Packets which contains
DSSS Modulated Data using NI-RFSG 5670.
While receiving this transmitted signal using RFSA-5660.
I am using the normal RFSA Programming flow to control my acquisition. Using Reference nodes, I set my other NI-Scope parameters Ref.Position, Trigger Level, Acquisiton time as required.
Other settings for NI-SCOPE and RFSA being set at default levels, With each acquisition of the BURST,I have a problem in acquiring more than a single packet.
While the keeps generating packets.. Everytime I run my RFSA Vi.. I can acquire a maximum of only one packet.
What setting of RFSA should I change to acquire multiple packets.. let us say 10-20 packets at a time ???
Thanks for your help...
(7,707 Views)
Hi RF_Buzzer,
Would you please attach a "simplified" version of your code that exhibits this behavior? I will try to reproduce this behavior.
Have a great day!
Brooks W.
(7,693 Views)
