RF Measurement Devices
RFSG 5673 Arb signals generation
Hi everyone!
I don 't understand how to generate an arbitrary waveform(PXI 5673). I created a conditional model with the desired waveform. The pulse duration and frequency were planned to be adjusted during operation. How can I transmit this signal to the generator? It is also unclear how I can count the number of these packets per second. For example, I have 1 packet of 10 pulses takes 0.3 microseconds. There should be 1000 such bundles per second. What generator settings do you need to manage to achieve the desired result?
Thanks so much for Your help!
(3,250 Views)
I continue to deal with the generator NI 5673. In the examples, I found several implementations of generating arbitrary waveforms. I tried to collect my own example, but I can't see rectangular pulses at the output. I see short sinusoidal pulses on the oscilloscope. Please tell me how I can get rectangular pulses on this generator? Is it possible?
(3,187 Views)
upd:
I did the task of generating the desired number of packets with pulses per second (I needed 1000 packets per second). I was able to implement this using a script. I also figured out how to set the signal duration and period. The smallest problem left is to get the shape of square pulses(right now a have only sine) Perhaps someone knows how to generate them on generator 5673?
(3,181 Views)
