RF Measurement Devices
RFSG error
Just start seeing attached error when starting RFSG app (hard reboot did not help!). Has anybody seen this before? any suggestion?
Rostam
(4,351 Views)
Hi Rostam,
This error often pops up when the RFSG driver somehow gets into a bad state, and can typically be resolved by performing a force reinstall of the driver. Here's a link to instructions on force reinstalling: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US.
One helpful tip, instead of manually navigating to the right location in the command prompt, if you shift+right click in the folder where the setup.exe application is located, you should get an option in your context menu "Open command prompt here." Click that and your command prompt should come up automatically in the right location.
Cason
Applications Engineer, NI
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
(4,292 Views)
"One helpful tip, instead of manually navigating to the right location in the command prompt, if you shift+right click in the folder where the setup.exe application is located, you should get an option in your context menu "Open command prompt here." Click that and your command prompt should come up automatically in the right location"
I never knew this! The things we learn
(4,262 Views)
