RF Measurement Devices
Reflected power frequency response measurement
My goal is to measure the reflected power from a DUT. I am using a Transmission/Reflection test set from Agilent to sample the reflected power and pass it to the PXI-5660. I sweep the signal over a range of 100 MHz to 500 Mhz and measure the reflected power signal at each point. A calibration sweep is taken first with a short at DUT end of the cable. I also sample the incident power with the T/R test set. The output signal is typically 0 dBm. My question is: What is the formula to calculate the reflected power from the signal measured? The signal I see on my application is not what it should look like.
(8,192 Views)
Hello Brian!
Your best bet at finding that formula is probably Google.  I did a search and got many different relection formulas and how to derive them.
Here is a derivation...
Here is a discussion and definition..
If neither of these are helpful if there something specifically with the 5660 I can help you with.  Let me know and have a great day!
Allan S.
(8,186 Views)
