RF Measurement Devices
TDM to ASCII
I made a file to convert TDM, then to write up the ascii file. At this
point,
this .vi can only handle one single TDM file. I want to put the loop this
.vi,
then to convert multiple number of TDM files into ascii with a serise of
names
such as T1.ascii, T2.ascii, and etc.
DK.
(9,438 Views)
Hi DK,
Thank you for contacting National Instruments.  I added to your VI to allow automated conversion of TDM to ASCII simply by selecting the directory where the TDM files are stored.  I have attached a screenshot, but if you would like the VI, please let me know what version of LabVIEW you are using.  Hope this helps.
Donovan
(9,418 Views)
If you can provide the vi file same as in the figure, it should be much helpful. The version of Labview which I use is Labview 8.0
DK.
(9,414 Views)
Because some of the VIs I was using are not available in LabVIEW 8.0, I went through and made some changes, but it actually cleans the code up quite nicely.  I hope this works for you.
Donovan
(9,397 Views)
Dear NI,
I'm using NI Labview 2015 SP 32bit trying to convert TDM to ASCII file. I downloaded and succesfully used TDM80.vi but I need a different output file: I need all the values to be in column. With this vi I obtain a matrix, I need a vector instead. How can I change the output? And how do I know the number of rows after conversion?
(4,901 Views)
Hi Francesca,
What does the data file that you are currently using look like? Could you attach it?
If you need to take a subset of the array coming out of the Read Data (Channel) Express VI. You can transpose, take subsets, and sizes of the array if you need to convert a smaller portion of the array.
I have included links to another converter, as well as the array functions list to give you some places to get started.
Array Functions
https://zone.ni.com/reference/en-XX/help/371361M-01/glang/array_functions/
TDMS to ASCII File Converter
https://decibel.ni.com/content/docs/DOC-9642
Matt G.
Product Manager
(4,877 Views)
Dear Gryffindor,
I'm measuring tension values during time. After conversion TDM-ASCII, all the measured values are not a vector but a matrix. I wrote a Matlab function to manage them, even because with Matlab I can easily fit them. I used function "reshape" to get a vector from the matrix.
Thank you for your help
(4,826 Views)
