RF Measurement Devices
USB-5681 firmware update
The 2 ways I've found to update the firmware on the USB-5681 both do not work.  In the SFP the option is greyed out.  I launched the updater directly and it shows no sensor.
I have VI's I made that seem to work, but the sensor always seems to disappear or have problems in MAX that only a system reboot can fix.
(3,802 Views)
Those instructions relate to the NI USB-5680. We have not released any firmware updates for the NI-5681.
John Fenner
RF Software Engineer
(3,787 Views)
Hey Hepcat, can you give some details about your machine setup? Are you using a PXIe controller or a PC? How many USB devices do you have connected? Have you tried using a powered USB hub? What version of driver are you using?
(3,781 Views)
