RF Measurement Devices
Which are the hardware/software requirements in order to use Tektronix's Spectrum Analyzer RSA 3308A as a LabView instrument.
I need to use Tektronix's Spectrum Analyzer RSA 3308A as a LabView environment instrument for my school project, I would like to know if there are available drivers, if no drivers are available which are the implied software/software requirements to achieve this goal.
(7,272 Views)
Hi casillasr,
In searching the NI Instrument Driver Network (www.ni.com/idnet), I did not find this specific model of Tektronix Spectrum Analyzer, but I did find some drivers for different model numbers. You may be able to change some of these drivers to work with this specific application, but since I have never used the RSA 3308A, I do not know if it is similar enough to the other models to simply modify the code.
If you would like to create your own application to communicate with the analyzer, the hardware/software requirements are not excessive. You will definitely need a version of LabVIEW in order to create a program in the LabVIEW environment. Most of these external instruments communicate using GPIB, so you would also need a GPIB interface of some sort on your computer, along with the associated 488.2 driver. Then you will need to look in the manual to see what commands to send to your instrument to receive the proper information. National Instruments makes several different GPIB products, and you can find more about them here.
Good luck with your application! Let us know if you need help along the way.
john
(7,266 Views)
