RF Measurement Devices
calibrating PXI-5600
I am manually calibrating a PXI-5600 card using CalExec 3.2.2 which is out of spec at a few frequencies.
Having calibrated another 5600 card earlier, I would like to know if it is possible to adjust just the points that are outside specification? Otherwise, the adjustment procedure requires over 2,000 measurements.
Thank you.
(6,490 Views)
Hello Jerry,
Unfortunately that functionality to perform selective calibration is not there in CalExec 3.2.2. Hence the adjsutment procedure will require you to take all the measurements.
nAyer
(6,444 Views)
