RF Measurement Devices
configure N9010A attenuation in SPUR mode
Hi
Using CVI 2009 IVI Driver for the Agilent N9010A, I'm trying to measure spurius ....
to better the search criteria I need to apply 0dB attenuation to the instrument.
I can't find any API related to SPUR mode and attenuation and the APU "agmxa_ConfigureElectricalAttenuation" in the configuration menu only apply to
SWEEP mode.
any suggestions?
Regards Ofir
(6,487 Views)
Accepted by topic author ofirga
Hello ofirga,
I downloaded the IVI Driver for the device you specified and noticed a few SPUR Configuration function calls. I found these under the instrument library tree under Configuration>>Measurement Setup
Hope that helps!
Glenn
(6,458 Views)
