RF Measurement Devices
delta marker
I need some advice to point me in the right direction to carry out Phase noise tests using the PXI-5660.
I am a relatively new user to Labview/Teststand and working alone on a project and what I would like is a vi or information to do the following:-
I require Labview to do a phase noise test using the PXI-5660 with offsets from the carrier of 10Hz, 100Hz, 1KHz and 10KHz, the problem I have is how do I set markers using this instrument?. I want to place one marker on the carrier and a second at the carrier plus the offset then measure the delta between the markers and record the level in dBc/Hz. I am looking to set the markers using Labview without operator intervention i.e. no manual adjustment of the marker but set in the code.
Is this possible?
Andy
(7,602 Views)
Here is a phase nosie shipping example for the PXI-5660.
Andy Hinde
(7,588 Views)
Hi Andy,
Many thanks for the information I will try it out.
Andy Dunn
L3-Communications TRL Technology.
(7,579 Views)
