RF Measurement Devices
extracting portion of a recorded waveform
Hi. I'm using NI RF Phase-Coherent Multi-Channel Version 1.1. I'm recording and then playing back a signal. Is there a way that I could just playback a portion of the recorded waveform? For example, capturing a portion in the "middle" of the entire duration of the waveform? Thank you.
(5,909 Views)
Hi NathanDave,
This is possible, but not currently supported by the NI RF Mulrichannel software.I will add this as a possible feature for the next version.
One way to workaround this and still use this software without any modifications would be to create a new binary data file containing just the portion of data you wish to regenerate, and then replacing the original data file with this new file.
Andy Hinde
RF Systems Engineer
(5,908 Views)
Hi. Sorry for bothering you with another question. How can I edit the binary file? Can you recommend some software applications that can do this? Because at this moment, I can only edit the excel file of the two channels. I don't know how to handle/edit the binary file. Thank you.
(5,895 Views)
Hello Nathan,
For editing any binary file you may use a hex editor program.  The steps will be different on each program but you would just copy the number of bytes you woud like starting from a certain point and then create a new file and paste those bytes and save.
Anthony F.
Staff Software Engineer
(5,883 Views)
