RF Measurement Devices
frequency hopping with 5671
HI
I want to generate a hopping signal with PXI-5671 RFSG and want to analys with PXI-5660 RFSA. The frequency range in my case is between 200-300Mhz but i will use 200-220Mhz due to BW limitation of 20Mhz.The hopping rate i wil use is comparitivly i.e. 10-20 hops per second..
I m new with the hardware, i have used it to generate and analyz the signals but stil unable to generate the hopping signal with predefined hopping sequence and hopping rate.
can you guide me that how to do this????or can u give me a VI so that i can learn from it and regenrate with my specs to chk weather it works or not...??
I wil b realy thankful if u can help me in anyway....
REGARDZ
(6,095 Views)
can someone help me with this?????/
plz tell me ,IS IT POSSIBLE?????if yes, then how to do this...the details r given in the first post...
REGARDZ
ADNAN FAZIL
RESEARCH ASSISTANT
(6,080 Views)
