RF Measurement Devices
labview driver for keithley S46 32 channel switch system
I am looking for labview driver for keithley S46 32 channel Switch.
As a matter of fact I already found the old driver for Labview v5 and v6, I would like to know the current Labview 8.2 is it backward compatible if I used the old driver for the keithley S46 32 switch ?
flam
(6,914 Views)
Should be. You don't mention, though, where you got the driver or the type of connection (serial, GPIB, etc.) that the instrument uses or even the type (LabVIEW, IVI, etc.). Try it and see what happens. If your have any problems, post back but in the correct forum. Your switch is not an NI RF device. The best forum would be the Instrument Control Board.
(6,905 Views)
