RF Measurement Devices
make frequency response analyser using frequency generator and counter
Hello
Can we make a frequency response analyser using a Frequency generator and frequency counter?
How to add modulation with it? Modulation frequency is to be varied as per the input to given to the carrier!
The outputs are Frequency, magnitude, and the phase as like solartron FRA.
somebody have an Idea for this
awaiting for the solution
thank you
"Thanks with regards "
by
..........Gireesh..........
(6,605 Views)
Hello Gireesh,
You can use a function generator to generate frequencies and use the modulation tollkit and other tools availabe with LabVIEW to do the modulation part . Or you can use the analog output ports on the daq card to generate different frequency signals for the same purpose .This should pretty much serve your purpose.
http://zone.ni.com/devzone/cda/epd/p/id/5646
http://digital.ni.com/manuals.nsf/websearch/AF3615F31CE9656C862576070020B8F7
(6,578 Views)
hello
thank you sudeepn
this is very helpful to me
by
(6,558 Views)
