RF Measurement Devices
memory limit 5660
I want to acquire a signal of 160 MHZ using 5660. Can I set the sampling frequency to be 350 MHz? I want to acuquire the signal for 5s. How much memory is required to acquire the signal? Will there is any limitation in memory usage?
Rajesh.
(7,521 Views)
Rajesh,
You can definitely acquire and analyze a 160MHz signal (up to 2.7 GHZ), but your sample rate is always 64MS/s. This is possible because the PXI-5660 is made up of two two PXI modules, the PXI-5600 RF downconverter, and the PXI-5620 frequency domain digitizer. The PXI-5600 performs a down conversion of the 160MHz signal to a lower freqency before it is read by the PXI-5620 digitizer and analyzed using the spectral measurments toolkit (SMT). If you sample for 5 seconds reading samples of type double (8 bytes), you will be reading 64 MS/s X 8 Bytes/sample = 512 MB/sec per channel. For one channel, 5 seconds of data will be 2.56 GB. If you use a simpler data type this number will be less, if you use a larger (i.e. waveform type), this number will be greater. You can learn more by reading the The NI PXI-5660 RF Signal Analyzer Extends Virtual Instrumentation into GHz Applications tutorial.
Jessica
Applications Engineering
Message Edited by JKnMI on 09-30-2005 12:24 PM
(7,514 Views)
Hello Rajesh,
A 5 second acquisition at 64 MS/sec equates to 320 MSamples, which at 2 bytes per sample (the 5620 is a 14 bit digitizer) would require 640 MB of onboard memory, far greater than the 64 MB maximum offered. However, if you are acquiring a narrowband signal that is <= 1.25 MHz the onboard Digital Downconverter (DDC) will turn on on the 5620 digitizer, which reduces the data rate.  However, when the DDC is on, each complex IQ sample is composed 4 bytes. At 1.25 MHz, the sample rate becomes 2 MS/sec, which at 4 bytes per sample and 5 seconds comes to an onboardd memory requirement of 40 MB, which is possible with a 64 MB 5620. Smaller bandwidths reduce the sample rate even further, so if your acquisition bandwidth is <= 1.25 MHz, then a 64 MB 5620 will do the trick.
Andy Hinde
(7,503 Views)
