RF Measurement Devices
newbie rf - acuqisition
I have a wireless temperature monitor that passes temp to a receiver - is there a way to acquire this data via PC? Thanks for any help...
(8,215 Views)
National Instruments almost suredly has a solution for acquiring your signal. The only reason I say almost is that I don't know more about the signal itself - can you provide more info regarding the transmission frequency and modulation scheme used by the temperature monitor? These answers will help me provide the most cost-effective solution that NI can provide that will allow you to capture this data via the PC.
(8,215 Views)
