RF Measurement Devices
power edge trigger for IQ acquisition with ni 5660 configuration
hey,
I would like to do an IQ acquisition with a power edge trigger, I would like to know if it is possible with the PXI-5660 configuration (Labview 8.5).
I know there is a VI on RFSA "power IQ", is there a similar solution on ni5660 library?
I tried to implement the VI "analog edge trigger", I think it can be a solution for my acquisition, and I have this error :
"Invalid value for parameter or property. Analog triggering is only supported in normal acquisition mode."
I don't understand why.
Someone can help me?
thanks in advance
Seb_MDI
France
(6,645 Views)
Salut Seb_MDI,
You might find useful this thread I had with Guetteur. There is a shipping example that has already a burst detection VI that can help you debug yours.
I mention this since the PXI-5660 does not have power trigger build-in the hardware and therefore there is no NI5660 driver call for it. The PXI-5661 does have that capability and you would be able to use the NI-RFSA driver for that.
Analog trigger is not the same as power trigger. You basically want to fetch IQ data and perform a power detection (I^2 + Q^2) and based on the power, you will keep the values or drop them.
Let us know if you have more questions.
Gerardo O.
RF SW Engineering R&D
(6,629 Views)
