RF Measurement Devices
transmission of jpeg file
I want to transmit jpeg image between 5670 RFSG and 5660 RFSA through QAM . Is there any example that does that or if not then can you please tell me how to do that using existing examples
(6,693 Views)
Using the Modulation Toolkit, you can generate a QAM modulated signal. It looks like there is a basic example which simulates QAM modulation and demodulation. In it, a JPG image is converted to a binary bitstream. This bitstream is then modulated onto the chosen carrier sine wave frequency. This is a basic example, and will require some work to adapt to your application.
This looks like your best starting point for what you are trying to do. I also encourage you to look at the examples that ship with the NI-RFSG driver and the Modulation Toolkit. You can view these for LabVIEW in the Example Finder (LabVIEW » Help » Find Examples » Hardware Input and Output » Modular Instruments » NI-RFSG).
Aaron
(6,688 Views)
The link specified was very useful. But, when I try to run it, it shows an error (missing MT Generate Bits.vi). I tried to compare (MT Generate Bits.vi with MT Generate Bits (Poly).vi in LabView) but it does not look like same. Can you please send the link where i can download the MT Generate Bits.vi, which will be very much useful to run Simulated QAM modulation of a JPG ImageSimulated QAM Modulation of a JPG Image.
Thank You in Advance.
(3,188 Views)
