RF Measurement Devices
what is the maximum frequency labview can alter the phase of?
Hi thanks for using the forums,
to help solve your issue quicker could you answer the following:
Whats is it that you are trying to do, could you explain in more detail?
And what is your system set up (ie version of LabVIEW) ?
Regards
Jordan Power
(7,110 Views)
Hi Dannyboy,
This is a very vague question. I'm just wondering what your application really is. Is it a pure software application? If this is the case then the minimum and maximum values can be determined based on the data type you are using ( float , double , ..... )
The other thing that would be good to know is if you are generating/acquiring data related to  a hardware setup that you are controlling in LV. If that is the case, can you please specify what hardware you are using, because that mainly depend on the hardware spec of the device you are using.
Best Regards,
Faris A
Bueller
(7,089 Views)
