RF Measurement Devices
when Generating RF signal i want to add noise with sine wave, it is possible or not?
Hi all i i want add noise with sine wave of RF signal pls give some suggestion on this
Santhosh M
(7,418 Views)
Hello Santhosh,
What NI RF signal generator are you using? Is it a vector signal generator like the 567x series? Or, a CW generator like the 565x series?
Abhishek
(7,416 Views)
Hi Abhishek,
I am using 567x series, all I wanted to know is can I add noise to analog modulated signal and only cw signal? Can I have control over the noise that I want to include along with modulating signal for modulation?
Santhosh M
(7,414 Views)
Hi Santosh,
You could use the MT Add AWGN.vi that is included with the Modulation Toolkit to do this:
If you don't have the Modulation Toolkit, you should be able to use other LabVIEW functions to add this noise in software.
-John
Message Edited by John P on 04-16-2009 07:33 PM
John Passiak
(7,287 Views)
