ROS for LabVIEW(TM) Software
Is this library still valid? Any alternative?
Not seeing a lot of motion over the years?
is there a better toolkit or is there an alternative approach?
(3,612 Views)
I am trying to setup LabVIEW talking to Gazebo through ROS, if you are interested to be part of a group where we could get the software updated, please email me at jacobs.mathews@gmail.com
(3,342 Views)
Hi
I have been trying to create a ROS master in LabVIEW and connect to it from Ubuntu (We have a robot setup connected with Ubuntu). So far no luck! I am using the ROS_Master_Main.vi and _ROSdefinition.vi to create such a master. Interestingly, I can connect to it from the same pc, I cannot retrieve any node or topics though. More importantly, I cannot connect to it from any other machine. I also made sure that everything was connected to the same wifi connection.
Do have any suggestions?
Thanks for your time
(2,837 Views)
