RTI DDS Toolkit for LabVIEW Support
Building an executable with the rtilvdds.dll in LabVIEW 2017, error "rtilvdds.dll not found"
Hello all,
I have a project that I've written in LabVIEW 2017, and it runs fine on my development machine. When I try to build it into an executable, the rtilvdds.dll gets pulled into the 'Data' folder, but when I actually run the executable, I get the following error: RTI_DDS_Error.PNG
It gives me this error for any VIs that use any components of the toolkit. Do we know if the DLL is compatible with LabVIEW 2017, or if there is any issue when building it into an executable?
Thanks for the help!
(6,029 Views)
Hey aprillest,
I'm not sure if this applies to the toolkit but it is possible that we have to configure our system similar to how it describes it in this document below.
Set Up the Environment on Your Deployment Machine - https://cdn2.hubspot.net/hubfs/1754418/RTI_Oct2016/PDF/RTI_CoreLibrariesAndUtilities_GettingStarted....
JY
Application Engineer, RF and Communications
(6,019 Views)
Accepted by Nick-C
Hi aprillest,
In the "Common questions" topic we have a section which explains how to fix this issue:
I hope this helps!
Angel.
(6,009 Views)
This is what I ended up doing.
Thanks for the link!
(6,003 Views)
