RTI DDS Toolkit for LabVIEW Support
Cannot see topics in LV if sender is stopped and restarted
We are using RTI DDS for LV to communicate with a non-LV system.  What we are seeing if the publisher is stopped and restarted while the receiver (reader vi is running) communications stop.  It is necessary to stop and restart the VI (and sometimes the LV development environment) to reestablish communications.  The reader VI is the example reader VI generated by the RTI tool kit.
(3,286 Views)
Sorry for the late response. Is the issue still persisting? Can you provide more details about it? Like DDS Toolkit version, LabVIEW version, bitness, system where you are running LabVIEW... Also providing the ctl file you are using (or an equivalent that reproduces the issue) so we can test it would be a great help.
(3,238 Views)
@ismaelrti
thank you for the reply.  We have narrowed down the problem to an issue with QoS settings between the sender and RTI DDS.
(3,218 Views)
Hi FireflyAutomatix,
I'm glad to hear you solved the problem. Could you describe what was causing the issue and how you solved it? It could help us and other users with the same issue as well.
Regards
Ismael
(3,205 Views)
