9205 cRIO Random Interleaved Sampling Example
Hello Friends
Have any of you done any random Interleaved Sampling with 9205, on FPGA/RT (cRIO), any example codes?
Please consider we would like to measure 50KHz signal at 3 differential channels of 9205.
Can I use multiple channels (3 channels) on 9205 sequentially, as a single channel to benefit from the aggregate scan rate, definately with cRIO (FPGA/RT)?
Thank you for your kind help!
Regards
(4,113 Views)
There aren't any specific examples using 3 channels, but here's something somewhat similar. https://decibel.ni.com/content/docs/DOC-6303
What's the reason the signal has to be read on 3 differential channels?
Daniel Parrott
Software Product Marketing - Data Management & LabVIEW
(4,085 Views)
